8 members (2-Ton, Peggy M, TUTS 59, JW51, walter74, moparguy, NJC, 1 invisible), 175 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#468382 11/06/2008 3:44 AM
V
V Offline
Anyone have info & photos of a tubular type engine mount kit install for smallblock chevy engine set up. 51 chevy frame(with mustang II IFS set up)
The Fatman has one. Check out his catalog at www.fatmanfab.com at the bottom center of page 10 is a pic of his. $65 a set.
I have a set that I have yet to install. They are the real deal, the tube must be 1/4" thick, I haven't mic'ed it but I can if you want to know or want some pics. Get it welded in and it isn't going anywhere.
R-Bo
1966 GMC 305V6 in the family
V
V Offline
Thanks for the link R-BO. Quality & strenght good solution. Now my problem is, I had previously bought the transmission & engine tubular bracket in the style that fits between the frame & extends under the donor engine or trans. This was the kit recommended for 47 to 53 chevy pickup small block install. I was wondering if someone might have a photo of such an install in their own truck. The trans. mount seems to line up fine.
I'm right now in the process of putting in Classic Performance tubular engine and trans mounts for a sbc and 700r in a 52 GMC. Got the trans mount in, but not the engine mount yet. I might be able to get the engine mount in this weekend, I'd be glad to post some pics if I do.
V
V Offline
Hi mikes old pickup
How did you make out with your engine install. Photos would be great if you can. Thanks
Would like to see the pictures as well. Thanks
