| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | My vacuum wiper motor was acting up so I ordered a new one with a replacement wiper arm and wiper from Jim Carter.
What arrived wasn't anything like what was already on the truck.
The old wiper had a round knob that the wiper arm attached to. This knob was attached to the wiper shaft with a small pin.
The new wiper motor is the same as the old one and I can put the knob and old wiper on but the new wiper arm has a rod that runs all the way through with a spring that looks like it would attach to the shaft with out the knob.
I can't figure out how this setup works.
Someone must know how this works. I'll take hints or step by step instructions.
Thanks | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | The knurled knob was used with an aftermarket arm (like an anco) the new are you got is made like the original style arm. it is real hard to describe how to do this here. Give Mike a call at Jim Carters and let him guide you over the phone. | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | | | |
