| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I just bought the chrome waterneck you see on the 'bay, and it has no provision for a Thermostat! I will not run without a stat, so I'm gonna chuck it up in my 4 jaw on the lathe and turn a recess to accept one. I don't know how much a machine shop would charge, but if anyone in socal want it done I'll do it for just a coupla bucks ( to cover the 1/2 hour or so it'll take)!
Who is John Galt?
| | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I bought a polished aluminum water neck (for a 235) just because I needed a straight up rather than an angle. Got any pictures?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Hey, anybody install a small block waterneck on a 235 outlet? I don't know the bolt spacing difference, or if they will seal at the edge.
Who is John Galt?
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I bought a chrome straight up one for a v8. It fit fine on my 235.
regards, Leon
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They are the same. I helped a guy put a 355 in a '49 1 ton once, we used the original 216 housing on the V8 intake.
Bill Burmeister | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | the one on the 'bay comes with the lower portion as well it ran me about $40.00.
Who is John Galt?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The ad I saw on EBay for a water neck like you describe states that there is no provision for a thermostat. Not sure why they would sell it that way except that it's imported and maybe don't know any better.
Drew
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Thats the one I got! it looks really nice, but the small recess for the thermostat is absent. I'm gonna chuck it up in my 4-jaw on the lathe and cut my own recess.
Who is John Galt?
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Well, I got my chrome outlet to the shop, and it turns out the hole where the thermostat would normally go is larger on the chrome one. Larger as in as large as the thermostat o.d. itself! So now I think I'll have to make a press in shelf to hold the thermostat.I think if I make it a tight fit, and use some green loctite, it will work.
Who is John Galt?
| | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Valuable information. Thanks.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | I have one sitting on my bench at home. Pretty much a waste of forty bucks. I put the original from the 216 back on so I could hook up the radiator easier. The size of the throat is much larger that the original on the 1940. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Chrome t-stat housings leak! I've tossed several of them, and gone back to an OEM cast iron one. Don't waste time and money trying to make it work! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I was thinking that very thing!
Bill Burmeister | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I have a lapping plate to straighten it, and I was gonna use a small block "O" ring neck with it, as they are the best sealers in the neck dept. I have no worries that it will leak. I work on Harleys, so I know how to deal with leaks!
Who is John Galt?
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Could a guy use two gaskets and have one gasket be the seat for the thermostat? Just a thought. When I did the last re-do on my 261, I found the best stock 235 theromostat housing/water neck I could get my hands on, cleaned it up nicely and had it powdercoated with what was referred to as a "platinum finish". Came out nice! It's not chrome, but gives the illusion that it's something like it. It has held up very well! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | I would imagine the gasket would deteriorate and let the thermostat fall on its side. It would sorta obstruct the flow, but not hold it until it reaches operating temp. The thermostat is also a restrictor, slowing flow enough to accomplish heat transfer. Otherwise, if it just a matter of slower warm-up, I would be tempted to run sans thermo. I'm going to go buy some metal tubing to spin up in the lathe, and make a press-in shelf.
Who is John Galt?
