| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | I have a 51 GMC 100, and want to paint the underside of the cab, I have built a roller for the cab to sit on but it is not possible to paint the underside with the cab sitting on it, can the cab be set on the firewall to give easy access or will it be to unstable.
I am going nowhere fast and it's not taking me long to get there !!!!
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It will be unstable, but you can stabilize it with ratchet straps. Don't pull them very tight or you risk distorting something. I prefer to hang cabs with 2 spreader bars through the door openings and a spreader bar between the two spreader bars. If it has doors on it, tie the doors about half way open to prevent them from over extending. Hanging them back side up is how I weld patch panels on the lower back corner of the cab. | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | Thanks, do you put the cab firewall down prior to lifting thru the door openings, It is just the cab no doors , glass ,seat ect, It only appears to be about 250 lbs at the most, my son have lifted it a few times, I just dont want to damage the cab.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | Thanks, I have a good idea of how I'll do this now !!!
