1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#46988 06/28/2005 3:50 AM
Junior Member
Junior Member
Yes, Ive finally tired of the 216 in my 51 sedan, and my brother-in-law is parting out a 82 full size chevy truck with full engine/transmission/power steering/ any accessories I need.
The only problem: I have a fairly constricted bank account and im looking for some advice on how to do this right and cheaply. Theres plenty of space for the 350, but im sure everyone that's tried this has ran into problems, and I was looking for pointers.
Any and all advice is appreciated
I know about some of the necessary changes: 12v lights, voltage reducers, 3.?? gear ratio in rear.
-Brad
[email protected]
#46989 06/28/2005 7:37 AM
I've seen and heard alot of things about stuffin' a 350 in old chevy cars and trucks.. and it usually ends up in cutting and welding.
At the very least, they say the 350 engine is longer, so you have to move the radiator forward.. and i've heard the 216 radiator isnt big enough to cool a 350, so you gotta use the 350 radiator.
If I ever get a old truck or car and decide it needs a 350, i'd go the full monte, and get a later model GM car or truck and just swap bodies.. that way you get the disk brakes, the suspension, air conditioning, and all the other perks assoicated with a later model vehicle.
Have a look in the TechTips section of this website.. there is at least one article regarding putting a V8 in an old truck.. not sure how much of it would pertain to a car, but i'd guess they're close.
#46990 06/28/2005 8:54 PM
Brad,
Do you still have the torque tube driveline and original rearend? Those will need to be replaced if you go with the 350. Another good place to look for some pointers would be the hamb:
http://www.jalopyjournal.com/forum/
There's a lot of hot rodders there that could probably offer some good advice on what you want to do.
#46991 06/28/2005 11:43 PM
I thought that the 350 was shorter than the inline. Hmmmmm. What say you?
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#46992 06/29/2005 1:42 AM
sbc shorter and lighter than your stovebolt.
I've got one in my 52 coupe, I bought the walton fabrication mounts, they are weld in, but they are located using existing bolts, worth every penny and an HEI clears
Instrutions are included and Todd Walton will talk you through it (including trying to sell you a bunch more of his really cool parts).
