| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Probably the same for 235's, too, but:
My dipstick tube for my 261 is non-existent and I need to make a new one. When considering the length I need to know where the oil level should be in the pan. Of course it's somewhere in between the oil pump pickup and the crankshaft, but can someone tell me exactly where it should be or how long the tube should be (from the flat of the block to the top of the tube, and the length of the dipstick)?
Thanks, Dave
Dave
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | wouldn't it be easier to drain the engine and then add the correct amount of oil and then mark your stick. then you would be sure that its right. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | That'd get me close, but I want to know just how far off the bottom of the crankshaft counter balances the oil level should be.
Dave
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Can any of you guys tell me about where your dipstick says your oil level is on you six relative to the top of the oil pan?
Dave
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | I made some measurements a couple of years ago when I put my 1954 261 together, and (if I can read my notes) the top of the oil is about 4-7/8" below the block flange. I was not trying to make precise measurements, so I would not bet a lot on the number.
Hoyt | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks much, Hoyt.
So does anyone know if the oil level is supposed to sit just out of reach of the crankshaft when the engine's off, or is it just touching, or what?
Dave
