6 members (Peggy M, Danielbolt, DaveV, dunfire, Greg_H, papas52), 90 guests, and 0 robots.
Topics128,157
Posts1,056,878
Members48,458
#469406 11/09/2008 5:02 AM
Has anybody had the problem of oil sipeage from around the hole in the block where the Dist. goes in. Fixed how? , o-ring, gasket, silicone, suggestions? Thanks to all.
The best fix would be to machine a groove or two around the distributor housing for about a 3/32" O ring. The original HEI distributor used a gasket between the block and the distributor housing, but once that flange is machined or filed away, there's nothing to seal to with a gasket. A lathe cutter with the correct radius to fit an O ring would be pretty simple to fabricate.
Riding in the Passing Lane
Is your roadraft tube clean & is there a breather cap on the valve cover? I'm wondering if you are building up pessure in the crankcase. You could put a little RTV on it & set the timing before it sets up.
1972 Chevy c10 Cheyenne Super
Thanks for the replies, The tube is clean and I do have the breather cap on it, I think I'll try an o-ring or a bead of silicone. Thanks to all.
man a lot of guy's go through a lot of grief on the hei conversion my old man just used the stock 250 hei left the clamp shoulder (no leak )and made a intermediate shaft to pin on to the end of the shaft to engage the oil pump .don't look trick but eliminates a lot of problem's .
i made a very simple gasket
it moves and no messy silicon to clean or redo.
Jim & Caroline
