| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Well things are starting to come together with my new 235 and T5. This is going in my 47 1st 1 ton. I decided to keep the original 5.14 rear end as the T5 has a .63 o/d which will keep me in the 2000 rpm range at 65 mph. I still have to figure out the mount for the emergency brake but otherwise it's going in the truck soon. | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | That looks great, nicely detailed, even the trany looks like you put detail work in to it. I just put a T-5 into my 54, but nothing as clean as yours. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a lokar ebrake handle mounted to the side of my t-5 but no pixs. my fabicator maded the bracket. look up steppenwood on this site he has pixs. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | Chato hows it going? ListenIm in the process of doing this t5 swap any info you can give me on doing it...Parts used and any problems you ran into...I will be doing the work myself and have some preconceived notions or nightmares. My last 54 chevy i installed a 250 with a 2004r trans and posi disc brake rear. this time around I want to keep the 235, but up grade the trans and the rearend? thanks bro | | |
