7 members (Jon G, DadsFirstPickup, dt235sd, TUTS 59, RLB, Otto Skorzeny, 52Carl),
166
Mod | | | Forums66 Topics128,130 Posts1,056,714 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Has anybody had the problem of oil sipeage from around the hole in the block where the Dist. goes in. Fixed how? , o-ring, gasket, silicone, suggestions? Thanks to all. | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | The best fix would be to machine a groove or two around the distributor housing for about a 3/32" O ring. The original HEI distributor used a gasket between the block and the distributor housing, but once that flange is machined or filed away, there's nothing to seal to with a gasket. A lathe cutter with the correct radius to fit an O ring would be pretty simple to fabricate. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is your roadraft tube clean & is there a breather cap on the valve cover? I'm wondering if you are building up pessure in the crankcase. You could put a little RTV on it & set the timing before it sets up.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Thanks for the replies, The tube is clean and I do have the breather cap on it, I think I'll try an o-ring or a bead of silicone. Thanks to all. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | man a lot of guy's go through a lot of grief on the hei conversion my old man just used the stock 250 hei left the clamp shoulder (no leak )and made a intermediate shaft to pin on to the end of the shaft to engage the oil pump .don't look trick but eliminates a lot of problem's . | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i made a very simple gasket it moves and no messy silicon to clean or redo.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
