| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46927 06/27/2005 4:53 AM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | Hey all, Got the 12 bolt truck rear mounted under my project, and noticed that the u-joint did not turn when I turned the wheel and tire... Pulled the inspection cover, only to find that the spider gears are gone from the center pin?!?!?! The rear came from a 77 full time 4x4 that had a blown engine, but why would some one go thru the trouble of pullin the two spider gears, and anyone know of a cheap place to get a pair of spider gears? Thanks, Garry K
Garry K in Pac Nor West 1948 Chevy PU 235 SM420 4 spd 1932 **** B pu 1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#46928 06/27/2005 1:56 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | I'd get your money back on that donor truck, its ending up to be a lot less than they told you it was. | | |
#46929 06/27/2005 2:01 PM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | Actually it has already paid for it's self, as I have made more off selling parts than I paid for it, so the rear was Free, and so were the brand-new 235x75x15 Wildcat RVT's on white-spokes. And I still have a few pieces left to sell. THe hulk is cut up and wil go to the scrap yard this week, and I will look to see if the scrap yard has a 12-bolt that maybe I can snag the spider gears from. I am also looking at finding a limited slip unit, then I can just replace the center, and the lost spiders will not be an issue. Thanks again, I just can't understand why someone would pull just the spiders??? Garry K
