3 members (Peggy M, TUTS 59, Maybellene), 175 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#46923 06/27/2005 2:04 AM
Planned on putting rings in my 46 burb and going over the head. Used the casting numbers on the engine (3835309) to order my rings. I know 48 & 49 #s. When I opened the package the 2 pressure rings were different sizes. The rings on my piston are the same size, and the same size as the largest of the 2 in the box. Is the year the difference. I'm lost as I don't want to order something wrong again (at $50 or $60 a pop). Taking the head to the machine shop tomorrow and will show them. Maybe they can give me some answers. Thought you folks might have some insight
Jim
#46924 06/27/2005 7:53 AM
X
X Offline
The 235 rings changed a couple of times throughout the years. For '41-'49, both compression rings were 1/8". For '50-'53, the upper compression ring changed to 3/32". For '54-'63, both compression rings were 3/32". All oil rings were 3/16".
Nowadays its harder to find the ring sets for the earlier 235's with the two 1/8" comp. rings, and many vendors only list one set for '41-'63. But they are out there. If you can't find them at your FLAPS, Hastings Manufacturing (hastingsmfg.com) and Deves Piston Rings (deves.com) both list the earlier sets.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#46925 06/28/2005 2:56 AM
46 burb,
I have some sets of older rings for that 235. e-mail me the size you want and I will try to help.
[email protected]
#46926 06/30/2005 11:12 AM
thanks guys. took the piston to the local machine shop and they are getting them for me. check out my post in panels and burbs for a couple of picts
jim
