The 235 rings changed a couple of times throughout the years. For '41-'49, both compression rings were 1/8". For '50-'53, the upper compression ring changed to 3/32". For '54-'63, both compression rings were 3/32". All oil rings were 3/16".
Nowadays its harder to find the ring sets for the earlier 235's with the two 1/8" comp. rings, and many vendors only list one set for '41-'63. But they are out there. If you can't find them at your FLAPS, Hastings Manufacturing (hastingsmfg.com) and Deves Piston Rings (deves.com) both list the earlier sets.
