5 members (37 GC, Otto Skorzeny, Ponchogl, 2 invisible), 156 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
This is just an "FYI" for those of you who are are putting a V8 or late six in your truck. Much of this applies mostly to '55
through '68 trucks. This does NOT apply to ANY 216, 235, or 261 engine!
"Late Six" refers to any inline six and the V6s based on the small block from late '62 or early '63 through '84.
All SBCs, most other Chevy V8s, and all late sixes have the same bolt pattern for the bellhousing!
You will need a V8 side mount cast iron truck bellhousing from '55 to '68. They all fit the 168 tooth flywheel. The aluminum bellhousing will not work without major cutting on the cross member. The only difference in the in the cast iron ones seems to be which starter is required.
Some common side mount, V8 bellhousing casting numbers for trucks are, 3738373, 3765710, 3733365, 3815891, and 3925505. There may be others. All those numbers fit the 10 1/2" or 11" clutch and the 168 tooth flywheel.
There are three common starter bolt patterns for the V8 bellhousing or late six. The earlier ones bolt to the bellhousing with 3 bolts. All those are for the 168 tooth flywheel. The other two types bolt up from the bottom and to the engine block. The starter with the 2 bolt holes 90 degrees to the crankshaft is for the 153 tooth flywheel, while the starter with the bolt holes about 45 degrees to the crankshaft is for the 168 tooth flywheel. Use whatever starter your bellhousing requires. Late starters will not work with early bellhousings due to starter nose interference.
Beginning with the first Chevy V8 in 1955, all V8 flywheels are either 14" diameter with 168 teeth, or 12 3/4" with 153 teeth. There are no other sizes. The early 168 tooth flywheels have a bolt pattern for a 10 1/2" clutch. The later 168 tooth flywheels have a bolt pattern for an 11" clutch.
The 153 tooth flywheels have a bolt pattern for the 10 1/2in clutch only.
From '55 to '62 the only V8 flywheel was the 168 tooth. The smaller 153 tooth flywheel was introduced in '62 or '63.
Almost all trucks came with the 14", 168 tooth flywheel drilled for either the 10 1/2" or the 11" clutch. There may have been a few drilled for both sizes, but no one I talked with has ever seen one.
The bolt pattern for the flywheel to crankshaft changed in 1986, but the bolt pattern for the clutch stayed the same.
In 1986, Chevy engines went from a 2 piece rear main seal to a 1 piece rear main seal. The hole in the center of the flywheel and the bolt pattern changed completely, but the clutch pattern stayed the same. This means, that if you put a 1986 or later engine into your truck, it will all bolt up except for the flywheel. You have to use one with an '86 or later bolt pattern. Your clutch, V8 bell housing and most transmissions will bolt up.
There has been a lot said about clutch disks here on the 'Bolt. I'll pass on that for now.
I'm sure folks will find corrections to and omissions from the above. I hope so! Note them and add them. I'm guessing that I've just scratched the surface.
Best wishes,
Les
Hey Less, Thanks for the info, wish I had all that in my head when I was puttin a 250 in my Burb!!
Les, Thanks for organizing & entering all that info. I've learned most of it the hard way thru the years & still have trouble remembering it. Now I've got it printed out - Thanks Again.
Doug
You are very welcome dd, and smitty! I knew that I couldn't be the only one who would need this stuff in print. When I get release bearing arms figured out, I'll add that. It looks like a cast arm MUST go with a cast bellhousing, but there are sooooo many....
All the aluminum bellhousings use the stamped arms, but I don't know yet if the cast ones will also work. I don't think so, but....
best wishes,
Les
