2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Anyone have info & photos of a tubular type engine mount kit install for smallblock chevy engine set up. 51 chevy frame(with mustang II IFS set up) | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | The Fatman has one. Check out his catalog at www.fatmanfab.com at the bottom center of page 10 is a pic of his. $65 a set. I have a set that I have yet to install. They are the real deal, the tube must be 1/4" thick, I haven't mic'ed it but I can if you want to know or want some pics. Get it welded in and it isn't going anywhere.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks for the link R-BO. Quality & strenght good solution. Now my problem is, I had previously bought the transmission & engine tubular bracket in the style that fits between the frame & extends under the donor engine or trans. This was the kit recommended for 47 to 53 chevy pickup small block install. I was wondering if someone might have a photo of such an install in their own truck. The trans. mount seems to line up fine. | | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | I'm right now in the process of putting in Classic Performance tubular engine and trans mounts for a sbc and 700r in a 52 GMC. Got the trans mount in, but not the engine mount yet. I might be able to get the engine mount in this weekend, I'd be glad to post some pics if I do.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Hi mikes old pickup How did you make out with your engine install. Photos would be great if you can. Thanks | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Would like to see the pictures as well. Thanks | | |
