2 members (Materman, 55shaker),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 28 Apprentice | | Apprentice Joined: Feb 2007 Posts: 28 | Anyone mind helping me ID this GMC engine. Was in a 1950 GMC 1/2 ton. Block # GMC 5 6107326 Head casting A245 6107412
the 245 might be 248? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I think GMC enfines have the displacement cast into the RH side behind the distributor if I recall correctly. The 245 or 248 on the head would not indicate displacement. Also try the OldGMC website. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, look for the stamped serial number on the boss on the front driver's side of the block. It will start with 3 numbers, those are the displacement. If there are only three numbers, it was a replacement block and you were supposed to stamp the rest yourself to match up with the block you replaced, so you wouldn't have to change the title. From this site: http://www.oldgmctrucks.com/Photos/GMC_Numbers.htmYou have a 228, probably original to the truck.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I looked it up and the block is a 39-52' 228. All the heads begin with 219xxx excpet for 2 which are both for the 228. | | | | | Joined: Feb 2007 Posts: 28 Apprentice | | Apprentice Joined: Feb 2007 Posts: 28 | Thank you everyone for the information. It is much appreciated along with the oldgmc website information. | | |
