10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible), 58 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#468238 11/05/2008 6:12 PM
Apprentice
Apprentice
Anyone mind helping me ID this GMC engine. Was in a 1950 GMC 1/2 ton.
Block # GMC 5 6107326
Head casting A245 6107412
the 245 might be 248?
Smittster #468247 11/05/2008 6:37 PM
I think GMC enfines have the displacement cast into the RH side behind the distributor if I recall correctly. The 245 or 248 on the head would not indicate displacement. Also try the OldGMC website.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #468281 11/05/2008 8:27 PM
Yes, look for the stamped serial number on the boss on the front driver's side of the block. It will start with 3 numbers, those are the displacement. If there are only three numbers, it was a replacement block and you were supposed to stamp the rest yourself to match up with the block you replaced, so you wouldn't have to change the title.
From this site:
http://www.oldgmctrucks.com/Photos/GMC_Numbers.htm
You have a 228, probably original to the truck.
Paint & Body Shop moderator
4ontheFloor #468304 11/05/2008 10:48 PM
I looked it up and the block is a 39-52' 228. All the heads begin with 219xxx excpet for 2 which are both for the 228.
Dave
53moneypit #468350 11/06/2008 1:54 AM
Apprentice
Apprentice
Thank you everyone for the information. It is much appreciated along with the oldgmc website information.
