| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | I am getting ready to re-attach the 3 speed to the bellhousing on a 235.
Should there be a gasket between these 2 machined surfaces? If not should I use some permatex, mostly to prevent any rust between the surfaces?
Bob | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bob, No gasket..dry is fine. There is probably enough heat and incidental oil to prevent any chance of rust. That's how I see it! Stuart | | |
