4 members (Shaffer's1950, cmayna, 2 invisible), 122 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
Is the driveline for a 1/2 ton Chevy AD pickup the same for both the 3 speed column and 4 speed floor transmission.
In other words, is it a straight changeout to replace one for another.
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
Someone correct me if I'm wrong...
First is that there were at least two, maybe three different 3-speeds used '47 to '55 1st.
Second, '47 to '54 all have the closed driveline, while '55 1st (all '55 ADs) have an open driveline.
Third, there is one more transmission option in the mix, which is the Hydromatic.
I believe, and this is where I'm a little uncertain, that each transmission option means a different drive shaft and torque tube (where relevant).
Most of this is information I've picked up here, so if I've gotten any of it wrong, please someone correct me...
According to my parts book, there were 3 different depending on year. One is listed for 1947 only, which was the last year for the old style tranny. One listed for 48-50, same part for either 3 or 4 speed. And one listed for 51-up. I believe the only difference between the 48-50 unit and the 51 and later was a change in the torque tube bushings, but I'm not 100%.
If your's is a 48-54, you would be able to swap a 48-54 1/2 ton 4 speed for a 3 speed,or vice-versa. The tranny must be from a 1/2 ton and you must use the corresponding u-joint for the tranny.
Bob
Bob I'm sure I've read somewhere that the Hydromatic trucks used a different torque tube. Is that incorrect?
I have changed an automatic (P.G.) for a 3 speed in a '52 it was a direct replacement with no change to the drive shaft so the two transmissions are the same length.
OldSub,
Yes, the torque tube for the 1/2 ton 1954 Hydra-Matic has a shorter length due to the longer length of the transmission.
The standard 3-speed, the heavy duty 3-speed, and the 4-speed transmissions are all the same length.
Tim
Junior Member
Junior Member
where can i get a hydramatic for my 1954 chevy truck? please advise someone. thanks, doug carter, haynesville, la. 318-245-1150
