| | | Forums66 Topics128,080 Posts1,056,291 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | need a radiator for this 1ton is it the same size as the 1/2 3/4 ton application,seems after reading it may be difficult to find a good supplier, thanks for any input, | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | On GMC the only difference in the radiators from 1/2 ton to 2 ton is core thickness. I think this also holds true for Chev. My personal preference is taking an old radiator to a shop that has been around a long time and does industrial radiator work and have it recored. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had mine recored and I am very satisfied with it. You know that it will fit when you get it back. | | |
