6 members (bucktruck, dt235sd, Stelonlevo, Hotrod Lincoln, Mike B, 1 invisible), 104 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
#467540 11/03/2008 2:12 PM
need a radiator for this 1ton is it the same size as the 1/2 3/4 ton application,seems after reading it may be difficult to find a good supplier, thanks for any input,
On GMC the only difference in the radiators from 1/2 ton to 2 ton is core thickness. I think this also holds true for Chev. My personal preference is taking an old radiator to a shop that has been around a long time and does industrial radiator work and have it recored.
I had mine recored and I am very satisfied with it. You know that it will fit when you get it back.
1951 1 Ton Completed
