Hi All,
I'm currently redoing the brakes in a '51 GMC 1/2 ton that sat outside uncovered for 10 years. As you can imagine, there's plenty of rust and dust. I'm back to the emergency brake linkage and cables. After a great deal of WD40 and some selective BFH pounding, I managed to free up the linkage from the pedal through the cross shaft that connects to the cables. Here's the question. When I step on the emergency brake pedal in the cab, it practically falls to the floor - mind you, I've got no cables attached at the drums yet. Going through Jim Carter's catalog I came across the attached entry
http://s456.photobucket.com/albums/qq286/blastenpene/Carter%20Ad/There was no linkage return spring on my truck. Sounds like there should be, but I can't even find any attaching points for it. Where does this spring fit? I had been wondering what pulled the emergency pedal back up when you released it, but I thought that it might be just the cable springs.
David B
