3 members (Hotrod Lincoln, TooMany2count, ranchojuan), 91 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#463104 10/20/2008 12:00 AM
what is the best for sandblasting and where do you get it. the paint that was brushed on my 49 gmc is like to bust up a cement floor. sand isn't working that well
JohnandDerek #463112 10/20/2008 12:18 AM
What do you have for a sandblaster? Sand should take off about any kind of paint. Aluminum oxide is probably best (IMO) but is very expensive. $40.00 for 50 LBS. I have a 40 LB pressure blaster I got at HF and at 90 PSI I took off paint, rust & anything else on the metal.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan's 57 #467011 11/01/2008 4:52 AM
Hello, JohnandDerek,
I have used coarse and med blasting sand from my local concrete dealer and did not care much for the sicla dust that came from it. I later found some at Northern Tool that was no scila that I liked better. It is called AmberBlast Abrasive Blasting Grit. It comes in a 50lb bag for like 10$. I think it did a good job in the 150lb blaster we used. I also have a small speed blaster that has a little tank on it I use for blasting small stuff. I blasted most of my cab with it and it worked good. It just took some time to keep reloading it.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
Michael1964 #467054 11/01/2008 11:22 AM
Black Diamond from Tractor Supply $7.50 for 50 lbs.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
