6 members (Hotrod Lincoln, Oswald, 1955 1 Series, Gdads51, Peggy M, 1 invisible), 119 guests, and 2 robots.
Topics128,089
Posts1,056,352
Members48,442
#465756 10/28/2008 9:44 PM
Apprentice
Apprentice
How much, if any, oil smoke is to be expected from the vents in the valve cover? I have noticed smoke from all three vents when I turn off the engine after its hot. I can smell it when I am driving. I know this is expected to some extent or the vents wouldn't be there. How much is normal is what I am asking I guess. This is a stock 216. Thanks
Riding in the Passing Lane
There should be no smoke when it is running. Its possible the road draft tube is stopped up. If there is very much smoke coming out of the vents or road draft tube it means the compression rings are bad. You might try a heavier weight oil.
1972 Chevy c10 Cheyenne Super
I suspect what you are seeing is water vapor from the vents condensing outside the engine, but you shouldn't smell any of that when you are driving. Usually any smell of oil while driving is from a leak. Have you looked for leaks? The valve cover is a good place to start looking, and also the side cover. If you see vapor condensing from the road draft tube when the engine is stopped, I don't think the tube is plugged, but it is a good idea to check/clean it. If there is concern of ring wear and blow-by, do dry and wet compression tests- an increase on compression pressure more than 20-25 PSI indicates ring or cylinder wear.
Harvester
Those vents are there for air to enter while the truck is going down the road. The draft tube is supposed to draw crankcase fumes out the bottom. You should take the draft tube off and clean it. It is also possible that you have worn rings.
1951 1 Ton Completed
Apprentice
Apprentice
What weight oil do you guys recommend for a '47 216. I have been using Castrol 10w-30. Any thoughts?
If it's loose 40 weight. At least that's what I use on my F$%# 2N.
~Jim
So, should the vents be open towards the front or towards the rear? Does the valve cover fit both ways? I get a bit of smoke out of the vents once the engine is off. ('47 216)
It's a small world, but I wouldn't want to paint it.
The vents face rear.
Harvester
You know if you let all the smoke out , it stops working ..... smile grin
I thought that was just for British wiring. smile
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
