2 Ways
1.) you can jack the rear up and count the revs of the pinion and the axle and divide
2.)Check the axle code. It's located on the passenger side of the axle toward the front of the truck about 3 " from the differential. It should be a 2 letter code begginig with H or J. Then go
Here to decode. Good luck.
