3 members (Dennys28, Wayne67vert, 78buckshot), 108 guests, and 0 robots.
Topics128,134
Posts1,056,402
Members48,441
#465385 10/27/2008 5:00 PM
I have a 1953 GMC series 100 with the 228 engine. But the engine that is in it has a reman tag on the side of it. I know that it does not run and most likely wont. The truck has a solid/enclosed driveshaft - that I do not necessarily want to have.
I have the oppourtunity to get the engine, tranny and drive shaft (that is running) out of a 54 (same everything - just about - just a 54 and chevy)- for a small amount of cash.
What changes am I looking at to get the swap complete.
The 1954 Chevrolet drive train, if original and from a 1/2 ton truck, will have an enclosed drive shaft and a transmission with an enclosed-drive-shaft fitting at the rear.
The GMC 228 engine is a longer engine than the 235 - maybe someone will discuss what modifications, if any, would be needed for motor mounts and clutch housing.
Ok, than the 54 chevy has an altered engine and tranny as well.The owner did not know for sure - just that it was a 235 that he though was original to the truck along with a 4 speed tranny.
It has an open (jointed) drive shaft. The rear end looked to be out of a later model GM product - could not tell what though.
Thanks for the help.
