BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
12 members (Fifty-Five First, Waveski, carbking, 52Carl, Otto Skorzeny, Danielbolt, Peggy M, Bill Hanlon, Lightholder's Dad, hapydirty, Guitplayer, cspecken),
541
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,301 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | I found a parts 56 or 57 LCF and am headed out to grab the list of parts I need. Anyone need parts for these as I am tempted to grab the entire truck before it heads to the scrapper but I don't have anywhere to store it. I would need to cut up whats not needed in a hurry and get rid of it. I have not seen the truck in person but it looks pretty solid and straight and has 6 lug 22.5 budd wheels on it.
| | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | You might want to save those wheels. If space is an issue, remove the front clip, as a unit, & get both doors, & you'll probably have , most of what you'd need, in the future. What would be left, of the cab, wouldn't yield much more than a pickup cab would. | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | Shop Shark Joined: Nov 1995 Posts: 1,159 | Yeah, we have several guys on here with LCFs who would probably be interested in stuff from that truck. And like Spanky says, the wheels could be very desireable (see Grigg's tech tip on wheels so you know what to look for). If they are the 10-lug 22.5 single piece rims, then I'd be very interested in them (if you or Spanky didn't want them)  John
~ One of many.
| | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | I'll check the wheels but I am pretty sure they are 6 lug's. If not I'll give you first crack at them.
Still not sure whether the entire truck is coming home or not. Time to talk nicely to my wife... Sweety - you know that camera you have been wanting...
Do the dash's come out as an assembly in these or just pieces?
| | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | Do like I do. Buy the truck, & worry about what the wife says later. I do it all the time. She's used to it by now. | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | That may be possible in the future but this will be 3 in a month. | | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | If the curved inner step area is rust free I'm interested in both sides for patch panels. They are called fender extensions, just below the door. Some one on this site was looking for the hood emblem not to long ago...don't remember who. Mike B  | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | I'm after the hoold emblem and that is the reason I am going after the truck, hood emblem, latches, chrome, etc. I'll check the fender extensions. The wheels are 6 bolt budd wheels not 10 bolt. I just picked up a set so I am going to pass on them unless i buy the entire truck. The truck is a winch truck with ginny poles, etc, possibly an old wrecker i suspect. | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Update. Truck is rough but there is still a set of 6 lug budd wheels, 22.5" tubeless. The rest of the truck has extra holes where they should not be and rust in the critical areas. Almost took home the Tulsa winch with PTO/ shaft but I pulled the lower drain plug and got water out so I passed.
Inner fenders were in nice shape but too much of a pain to pull. Exterior metal was rough.
I was able to save 1 hood latch, chrome from the hood emblem, side v-8 badges, throttle linkage, brake switch, and horn.
Are the old winches rebuildable or should I pass. I suspect with pto and shaft I would have 100 - 150 in the winch. | | | | Joined: Nov 2007 Posts: 4 New Guy | New Guy Joined: Nov 2007 Posts: 4 | I hate to ask on a Chevy site, but are the wheels interchangable with a ~74 Ford F600?
I picked up 4 tubeless tires but now need some wheels (6 hole Budds) to switch to tubeless on the Ford.
New wheels are $228 each + shipping.
Alan | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Alan, good news, I think so. Wheels I think are 6" wide, 22.5 tubeless, 6 on 8 3/4 bolt pattern. Bad news, wheels are 2 hrs south of Kansas City so probably 10 hours or so from you. | | | | Joined: Nov 1995 Posts: 5,470 Bond Villain | Bond Villain Joined: Nov 1995 Posts: 5,470 | Alan, You'd have to check the measurements to be sure, but I think they would fit your truck. The 6-lug tubless wheels I'm running on my '65 GMC firetruck came off a '70's F600 (ex U-Haul truck).
~ John "We are not now that strength which in old days Moved earth and heaven; that which we are, we are" 1948 International Farmall Super A1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump2001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | If trying to use 6" wide 22.5" wheels the books don't want you to put 9R22.5 tires on them (closest readily available and suitable size), they really need 6.75" wide rims, or even 7.5" rims. That said, I have 9r22.5 tires on my 6" wide rims, they don't rub each other on the rear duals, they mounted fine, and look good. However, I don't expect to load them to the max, or even half the weight they are designed to carry, so I expect they will be fine, but I'll keep an eye on them.
Grigg | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Grigg you bring up good points - for those considering 22.5 tires here is what i am running up against.
22.5 tubeless wheels run about 300 per 6 in the Kansas City area, then they need the old tires taken off, 10 per tire, then the old tire disposed of, 7 per tire, then sand blasted and powder coated, found a place for 23 per wheel but that was the exception, most were 50 to 65.
9r-22.5 tires are the only non-obsolete tires that show as being able to be mounted on a 22.5 rim. In the Michelin truck tire book the 9r is measured on a 6" rim.
9r tires are available but Expensive. $265 was the cheapest I was quoted for a new tire. I found 2 General take off's for steer tires at 180 each and will most likely be running caps on the rear.
Used 9r tires are not real common because many old farm trucks still use them. If you do find them used, prices have been pretty reasonable - 50 - 100 per tire usually still on a rim. Finding 6 that match, good luck.
I would have been money ahead finding the useable split rim 20's with lock rings and running them.
Ryan | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | | | | | Joined: Aug 2001 Posts: 3,436 Moderator | Moderator Joined: Aug 2001 Posts: 3,436 | Ryan Is your link the one you bought, or another one on the market? If the one on craigslist is still for sale, I'll be calling the first of next week. If anybody else wants it, have at it, the last thing I need is another neat looking truck to take care of.
2-Ton
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery'46 2-Ton grain truck | '50 2-ton flatbed | '54 Pontiac Straight Eight | '54 Plymouth Belvidere | '70 American LaFrance pumper fire truck | '76 Triumph TR-6 Of all the things I've lost in my life, I miss my mind the most! | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | Wrench Fetcher Joined: Sep 2008 Posts: 59 | I did not buy it but I saw it on craigslist and for 900 it would be hard to go wrong. It is still availabe as far as I know.
Ryan | | | | Joined: Aug 2001 Posts: 3,436 Moderator | Moderator Joined: Aug 2001 Posts: 3,436 | I called the farmer tonight and will be going to look at Wed. if it is not sold by then.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery'46 2-Ton grain truck | '50 2-ton flatbed | '54 Pontiac Straight Eight | '54 Plymouth Belvidere | '70 American LaFrance pumper fire truck | '76 Triumph TR-6 Of all the things I've lost in my life, I miss my mind the most! | | |
