1 members (carbking),
144
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I am attempting to connect a 1941 1 ton brake/clutch pedal/bellhousing assembly to a 7"powerbrake booster and dual chamber master cylinder. This set up used a rod that traveled from the brake pedal to a bell crank mounted on the frame and then back forward to the master cylinder.
I am installing a 7" power brake booster with a dual master cylinder to disk brakes in the front and drums in the rear.
Has anybody else attempted this? The bellcrank unit is my current complication. | | |
