4 members (Shaffer's1950, delwrench, rfs56trk, NJC), 114 guests, and 4 robots.
Topics128,162
Posts1,056,951
Members48,458
Junior Member
Junior Member
I am now through with the installation of the copper oil line that feeds the rocker assembly. Thanks for your help on this.
Two questions:
1. Just for my own curiosity, I did a ram down test on each cylinder before installing the rocker assembly. There was a little bit of leakage on each cylinder through the ports. ("Little bit of leakage" = (guessing here) about enough to fill a balloon in about 10 seconds.) The valves have just been redone and some of them even lapped. Is it normal to have a little bit of leakage? I am using about 80 pounds to do the ram down test.
2. I am now in process of installing the rockers onto the head. There seems to be one rocker that is tight even with the adjustment screw removed. Is this normal? Should I just go ahead and tighten the bolts to that hold the assembly in place and then adjust the valves cold?
Help.
The rocker that is tight may be because the cam lobe is right at the top , or , maybe the push rod is not seated properly on the cam follower.
yes do a preliminary cold adjustment , a little loose is ok , reset after the engine has run for 20 mins .
