| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46503 06/21/2005 6:12 AM | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | I am now through with the installation of the copper oil line that feeds the rocker assembly. Thanks for your help on this.
Two questions:
1. Just for my own curiosity, I did a ram down test on each cylinder before installing the rocker assembly. There was a little bit of leakage on each cylinder through the ports. ("Little bit of leakage" = (guessing here) about enough to fill a balloon in about 10 seconds.) The valves have just been redone and some of them even lapped. Is it normal to have a little bit of leakage? I am using about 80 pounds to do the ram down test.
2. I am now in process of installing the rockers onto the head. There seems to be one rocker that is tight even with the adjustment screw removed. Is this normal? Should I just go ahead and tighten the bolts to that hold the assembly in place and then adjust the valves cold? Help. | | |
#46504 06/21/2005 8:44 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The rocker that is tight may be because the cam lobe is right at the top , or , maybe the push rod is not seated properly on the cam follower.
yes do a preliminary cold adjustment , a little loose is ok , reset after the engine has run for 20 mins . | | |
