| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 18 Apprentice | | Apprentice Joined: Oct 2008 Posts: 18 | Does anyone know where I can find the C-channel? that supports the door window in a 1966 C-10? Neither the assembly manual or on-line parts stores seem to have this piece. I thought a new window regulator would come with all the parts necessary but no, and I can not seem to find anything about it. I need to install a whole new window assembly in the drivers door and am stalled trying to find this one piece (let alone actually installing everything!). | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Apopka, email me direct, I may have a spare set, [email protected] | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Most Automotive Glass shops will have some or can get it for you. If your channel is good and only needs the felt replaced they can get you the felt and rivets to install it in the channel. I did mine several years ago and it needs to be done again. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Oct 2008 Posts: 18 Apprentice | | Apprentice Joined: Oct 2008 Posts: 18 | Hi Jake,
thanks for the help before - I was hoping to find the lower window sash channel but have had no luck since last I spoke with you. You did mention a friend who was parting out or may have - I think his name was RJ Sisnero? or something like that. Ring a bell?
any help is appreciated. Thanks, | | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | | | | | | Joined: Oct 2008 Posts: 18 Apprentice | | Apprentice Joined: Oct 2008 Posts: 18 | thanks - emailed RJ to see if he can help. | | |
