0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi all,
I have been having brake problems recently with my 56 3100. The brakes are all stock except for a dual master cylinder & adapter from American Classic. All 4 drums were turned and new shoes installed about 500 miles ago and I put new lines on when I restored it 4 years ago. No power boost.
The brakes seem weak when I start pushing them and then when the pickup has almost come to a stop the pedal drops a little and the brakes grab hard. It feels like maybe I am getting only the front or rear brakes most of the time. Could it be air in the lines? Overfilled master cylinder? Something else? Any troubleshooting advice would be welcome! | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Hey Gradpa! Just a few questions... did you install a proportioning valve with the dual master? How about residual valves on the lines? Both of these items are needed to make a dual master work properly. Lots of info out there in cyberland on plumbing up a modern mastercylinder. | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi Smitty,
No external proportioning valve or residual valves. I didn't think they were needed with drums all around? The master cylinder is also designed for 4 wheel drums.
Thanks. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Normally you don't need a proportioning valve on drum/drum brakes and depending on what master cylinder your supplier sent you it may or may not have an internal residual valve. I would go back and revisit how the lines are installed and recheck the installation of all components. Also bleed the system again. This is usually a fairly straight foreward installation and you should not have these problems. You may still have to install an adjustable proportioning valve for the rears to make the system function correctly. Fred
