1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | I have a 1946 chevy pickup.The metal frame from the front windsheild is pretty beat up. It is rusted and corroded in several spots (although both sides are relative in one piece)My question is this: If I take a dremmel and grind off all of the remaining rust and then take small strips of fiberglass over the rusted and corroded parts so that the frame will become fiberglass with a metal skeleton. I am pretty sure I can recreate the channels in the corroded areas for the weatherstripping and window with my dremmel when the fiberglassing is done.Will this be stong enough when I put it all back together again? I would hate to go to all that trouble just to see the frame snap when it's put in place. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The metal frame X-section is pretty thin - not sure you could remove enough metal and rebuild with fibreglass. There is a splice bar that fits in the lower center bottom frame area which needs to be tight to avoid too much flex when you crank open the window. I ended up buying a new frame which is expensive, but mine was pretty far gone. You could always try the FG solution, the buy a frame if necessary. | | |
