| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 6 New Guy | | New Guy Joined: Dec 2006 Posts: 6 | Today was a milestone, After ten years of my 235 sitting on a stand I heard her run for the first time. My joy quickly turned to anguish as coolant spewed from the radiator. I have learned a lot from all the post and you guys have saved me lot of frustration so once again I come to you with questions. I think I have a restriction in the coolant passages. I running a 53 head on a 60 block and Im not sure I got the right head gasket, Im thinking the gasket is blocking the passages because the head is full of coolant and the petcock on the left side of the block is dry. Am I thinking right or am I missing something Help me out guys once again
I work & work & Work and I still cant afford it!
'50 3100 5 window ( under construction)
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The head gasket should match the holes in the head and the block. On some earlier years, there were holes in the head and the gasket that were dead ended at the block surfaces.
If the block has not been cleaned professionally in a tank, the petcock area is probably plugged. This doesn't normally present a problem. Your coolant surge may be the result of an air bubble. Also if the thermostat is stuck, coolant will come out the overflow as the motor warms. You could try running it without the thermostat first, to see if all works well without it. | | |
