7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 126 guests, and 1 robot.
Topics128,056
Posts1,055,799
#464308 10/23/2008 5:47 PM
I have a 54' 1/2 ton and am interested in swapping in a 292 I have. How difficult is it? Do they make kits with brackets, mounts etc?
Marc,
Here are motor mounts.
http://www.stoveboltengineco.com/acartpro/product.asp?productid=138
Maybe someone will comment on (1) radiator clearance issues, and (2) clutch-housing/clutch-linkage issues, and (3) transmission issues. And, post information about any other issues when using an original enclosed driveshaft.
Tim
Downhill bill Its not that complicated....I swapped a 250 into my 54 and it was work but fun work.Langdon's stovebolt has alot of parts, Tranny mounts, engine mounts alternator brackets and the issue of cleaarence really is not that big of an issue. Everything cleared fine a little treak here and there. JUmp in and you will see what I mean. The Hardest part was jacking up the truck in the dirt. ha ha ha ha good luck
#464424 10/24/2008 12:53 AM
howdy bill
all the photos you'll see here are about doing just that.
T5,292,clutch,&more
see
http://s67.photobucket.com/albums/h298/1951otter/
Jim & Caroline
Great pics of the 292 install very detailed, took me nearly an hour to look through them. I have thought about doing something like that with my next one.
