| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 1 New Guy | | New Guy Joined: Oct 2008 Posts: 1 | I have a 54' 1/2 ton and am interested in swapping in a 292 I have. How difficult is it? Do they make kits with brackets, mounts etc? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Marc, Here are motor mounts. http://www.stoveboltengineco.com/acartpro/product.asp?productid=138Maybe someone will comment on (1) radiator clearance issues, and (2) clutch-housing/clutch-linkage issues, and (3) transmission issues. And, post information about any other issues when using an original enclosed driveshaft. Tim | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | Downhill bill Its not that complicated....I swapped a 250 into my 54 and it was work but fun work.Langdon's stovebolt has alot of parts, Tranny mounts, engine mounts alternator brackets and the issue of cleaarence really is not that big of an issue. Everything cleared fine a little treak here and there. JUmp in and you will see what I mean. The Hardest part was jacking up the truck in the dirt. ha ha ha ha good luck
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | howdy bill all the photos you'll see here are about doing just that. T5,292,clutch,&more see http://s67.photobucket.com/albums/h298/1951otter/
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | Great pics of the 292 install very detailed, took me nearly an hour to look through them. I have thought about doing something like that with my next one. | | |
