4 members (Forty9, RdsLessTaken, Hanks custodian, 1 invisible), 82 guests, and 1 robot.
Topics128,264
Posts1,058,356
Members48,485
#464233 10/23/2008 12:23 PM
Hey guys, I have a 62 c-10 235 3 speed with hydraulic clutch. New clutch and pressure plate 10 months ago. Has worked great until a few days ago, my clutch pedal seems to loose pressure. For example, yesterday the truck sat all day at work, i get in to go home and i have to pump the pedal 5 or 6 times to get the pedal up where it needs to be to dissengage the clutch. What do you think ? Need a new slave cylinder? Any help would be appreciated. p.s. once i have pumped the pedal it is good to go until the next time it sits a while. Thanks
Riding in the Passing Lane
The master cyl is leaking off internally. Its best to put a kit in the master cyl. & slave cyl. both. They are easy to do & kits are not expensive. The cyls on the clutches are seldom pited because they take a full stroke each time they are used. It is still a good idea to run a hone through them.
1972 Chevy c10 Cheyenne Super
