| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | Can someone, anyone give me some tips on filling brake system on a 58 step side? System is all stock with everything new from master cyl, lines, to wheel cylinders.
Should I start at right rear,then left rear, then right front and end at left front?
Can I put a hose on 1 wheel cylinder and into a container so I can stay at master cylinder and add fluid as it is pumped into the lines and wheel cylinders? Then when I get fluid out of the line, close the valve and go to the next wheel. When all 4 wheels and lines are basically full, I can rebleed with the typical 2 person operation? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The correct sequence for a '58 is as follows, LR-RR-LF-RF. I would advise gravity bleeding first over trying to pump it through.Do put the hose on and route into a jar, but just maintain the level as it goes down, don't pump. do that for all 4 wheels. The you can do the traditional bleeding, however, again, don't "pump" the pedal. The manual actually states to depress the pedal 1 full stoke, then let it return slowly. I used this method on mine, works great. In my work (I'm a professional mechanic), I find that sometimes, you can cavitate the fluid if the pedal is pumped. I have had trouble with guys who get agressive with the pedal. Do as the manual says, slow and easy.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | heres my 2 pennies, when I completely redid my brake system I opened up one one wheel cylender at a time starting at the back farthest wheel an let gravity do its work until I could see a bit of fluid coming down the clear hose I had on the bleeder of each wheel then got the wife in the drivers seat and started bleeding off the the sytem ..was a fun day of messin with the wife and havin her HOLD pressure ..while I got a cold one ...till she figured out I was messin with her ...lol Tim | | | | | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | Thanks Longbox55 and SW Radial: I will do as you say in the next couple of days and report back with success or questions.
Bob | | |
