7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy),
57
Mod | | | Forums66 Topics128,008 Posts1,055,285 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | O.K. Here goes probably been asked a zillion times I am trying to find out what engine I got in my 53 3100. Where can I get that info? I have the head casting # & I believe the serial # off of the block.(located behind the dist) Thanks, Mel
If it ain't broke, fix it till it is
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hi Mel; Welcome to the shop. You can use the ID number stamped on the pad and look up the codes on this site:http://chevy.oldcarmanualproject.com/models/engine.htm OR - look up the casting numbers at www.inliners.orgThere's probably a lot of other ways to do it too, maybe someone else will chime in here. | | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | Thanks, I'll give it a whirl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | OR, post the numbers here and maybe someone can help you identify the engine. | | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | Good idea. The # stamped on the pad is 0139176T54Z. The head casting number is 3835913. I am also in the prosess of trying to find out if it has the stock carb on it and getting a rebuild kit /or new carb for it. I know it is a rochester auto choke no tag, couldn't see any #'s. Thanks for the help, Mel
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That's a 1954 235 automobile engine serial number (T54Z) and a 1954 235 head casting code. Is most likely has solid lifters. | | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | Thank you I appreciate the info.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | It does have solid lifters. The only hydraulic lifter engines in '54 were the "Y" code powerglide engines. | | |
