6 members (UtahYork, 78buckshot, dt235sd, Goach2, pauld, 1955 1 Series), 52 guests, and 4 robots.
Topics128,185
Posts1,057,286
Members48,467
#464088 10/22/2008 10:38 PM
O.K. Here goes probably been asked a zillion times I am trying to find out what engine I got in my 53 3100. Where can I get that info? I have the head casting # & I believe the serial # off of the block.(located behind the dist)
Thanks, Mel
If it ain't broke, fix it till it is
mtkr14 #464093 10/22/2008 10:51 PM
Hi Mel; Welcome to the shop.
You can use the ID number stamped on the pad and look up the codes on this site:http://chevy.oldcarmanualproject.com/models/engine.htm
OR - look up the casting numbers at www.inliners.org
There's probably a lot of other ways to do it too, maybe someone else will chime in here.
waldo53 #464102 10/22/2008 11:05 PM
Thanks, I'll give it a whirl
waldo53 #464104 10/22/2008 11:06 PM
OR, post the numbers here and maybe someone can help you identify the engine.
tclederman #464111 10/22/2008 11:24 PM
Good idea. The # stamped on the pad is 0139176T54Z. The head casting number is 3835913. I am also in the prosess of trying to find out if it has the stock carb on it and getting a rebuild kit /or new carb for it. I know it is a rochester auto choke no tag, couldn't see any #'s.
Thanks for the help, Mel
mtkr14 #464112 10/22/2008 11:40 PM
That's a 1954 235 automobile engine serial number (T54Z) and a 1954 235 head casting code. Is most likely has solid lifters.
tclederman #464152 10/23/2008 1:43 AM
Thank you I appreciate the info.
mtkr14 #464314 10/23/2008 6:10 PM
It does have solid lifters. The only hydraulic lifter engines in '54 were the "Y" code powerglide engines.
