3 members (tclederman, Otto Skorzeny, 1 invisible), 116 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#463626 10/21/2008 4:42 PM
4D6
Offline
Apprentice
Apprentice
I'm putting my front fenders back on my 1946 1/2 ton. I see fender welt in the catalogs but have no idea where it goes. There was none that came off but this truck has been through several restores so I don't trust the present state of things. How is is supposed to be?
Experience is the ability to recognize a mistake when you make it again....
4D6 #463637 10/21/2008 5:51 PM
Welt or anti squeak goes between the fender and the cab,running board, radiator support and between the rear fender and the box . Part number 10.0030 is the anti squeak or fender welt http://picasaweb.google.com/crenwelgeoil/AntiSqueak#5259650406121865090
crenwelge #463743 10/22/2008 12:51 AM
Not sure if factory stock trucks came with welting or not. I used it when reassembling my '40. It fills the gaps between body and fenders nicely. I pre-glued the welt onto the fender flanges with weatherstrip adhesive - makes things much easier to bolt together. Again, if you aren't going strickly stock, most Hot Rod shops carry welting by the roll.
1940 Chevy KC 1/2-Ton
Britcon #463964 10/22/2008 3:57 PM
I think they came with it because every fender I took off 50 years ago had it. However, back then we didn't replace it. After trucks were driven a year or 2, they rattled all over anyway, and nobody cared.
crenwelge #463973 10/22/2008 4:32 PM
I used welting on my 46. There is a short piece on the front fenders between the fender and the cab. The rears get the full treatment. I used some 30lb roofing felt between the running boards and the fenders. Front and back.
The roofing felt is a lot cheaper than the ones you can buy from the venders, and is the same stuff. You just have to make a pattern and cut it out, but that easy.
George
