1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | I think i have finally learned the problem with my engine. It diesels after i cut it off and the exhaust smells like raw gasoline. I asked my buddy who's a mechanic about this. He didn't say anything, walked past me to my truck, popped the hood, pulled out the dipstick and sniffed it. He then asked me to smell it. It smelled like straight up gasoline. He said that gas was getting into my oil pan and motor oil was firing along with gasoline in the cylinder and that can only be explained by bad compression rings or piston rings or whatever. So, we are planning to take apart the engine this weekend and change the rings, head gasket and piston(he calls them journal) bearings. Before I go off and do this, I wanted to check and see what my fellow bolters had to say. Do yall think the rings are what's wrong? | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | In a word- - - -NO! The gasoline is getting into the crankcase from a hole in the fuel pump diaphragm, or a carburetor that's flooding severely and filling the intake with gas, which then finds its way past the rings when the engine stops.
Severe flooding can wash the cylinders down, resulting in poor ring sealing, but once the source of the gas-contaminated oil is eliminated, it shouldn't be necessary to change the rings, unless they're worn out anyway. If the carbon deposits behind the rings on a old engine get washed out by gas-contaminated oil, the compression can drop severely because the carbon was the only thing keeping the rings in contact with the cylinder walls.
Find the source of the gas, which will probably be the fuel pump, then fix it, change the oil, and run a compression test. Anything around 85 pounds or more, up to maybe 100 PSI, will mean the rings are probably OK. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You mentioned fellow Bolters so I will answer also. I agree with Hotrod. After you do that if the comp. is good & it doesn,t have excess smoke or oil consumption, leave it alone. If it still deisels after that post it & we'll deal with that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | +1 on what Mr. Lincoln says.
The rings aren't causing the leaky gas. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Yes, to the previous responses. Beyond that, the dieseling is most likely caused by the idle speed being set too high. There are other possibilities for that, but start with lowering the idle speed. Advanced ignition timing and lean idle fuel mixture can also contribute to dieseling, although if your truck has a functioning PCV system, and there is gasoline in the oil, you most likely won't have a lean idle mixture.
Harvester | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | I agree with all. Pulling the motor down will not fix the problem. The gas in the oil is due to the too rich mixture washing down the cylinder walls. Try with timimg & carb. adjustments first. I have a ford 460 cid and have to change the oil often due to rick a mixture when the motor is cold. | | |
