| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | I'm putting my front fenders back on my 1946 1/2 ton. I see fender welt in the catalogs but have no idea where it goes. There was none that came off but this truck has been through several restores so I don't trust the present state of things. How is is supposed to be?
Experience is the ability to recognize a mistake when you make it again....
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Not sure if factory stock trucks came with welting or not. I used it when reassembling my '40. It fills the gaps between body and fenders nicely. I pre-glued the welt onto the fender flanges with weatherstrip adhesive - makes things much easier to bolt together. Again, if you aren't going strickly stock, most Hot Rod shops carry welting by the roll.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think they came with it because every fender I took off 50 years ago had it. However, back then we didn't replace it. After trucks were driven a year or 2, they rattled all over anyway, and nobody cared. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I used welting on my 46. There is a short piece on the front fenders between the fender and the cab. The rears get the full treatment. I used some 30lb roofing felt between the running boards and the fenders. Front and back. The roofing felt is a lot cheaper than the ones you can buy from the venders, and is the same stuff. You just have to make a pattern and cut it out, but that easy. George | | |
