| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 29 Apprentice | | Apprentice Joined: Nov 2007 Posts: 29 | we have a 1946 chev 1/2ton pickup with a 55 235 engine. The problem is after about 30 minutues or so of running the engine the fuel system seems to be vapour locking. No fuel in the carb. Have tried several things to correct the problem, venting the fuel tank, changing the fuel pump back to an original sytle fuel pump, changing the fuel lines, but it still has the same problem. had the fuel tank cleaned and relined, but nothing we have tried has fixed the problem. checked the carb, but can't find anything wrong. Running out of ideas to what could be causing the problem. Looking for suggestions to what could be causing the problem | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | shmkr,
Reading the list of all the things you have done and changed, It's hard to believe that it's the fuel system. How are you determining there is no fuel in the carburetor?
What happens if you let the engine fizzle out, then pull the fuel line at the carburetor and crank the engine over, sticking a can or bottle over the end of the fuel line. Does fuel come out or is it really bone dry!
Does this problem happen if you let the rig sit in the driveway and idle..will it still die after half an hour or so! That's way too long for a typical fuel blockage to happen, and especially if it does it consistently, from a cold engine to a warm engine.
The empty carb is the giveaway, but if this isn't actually happening, the ignition could be suspect. Coils have been know to give up the ghost when they warm up, then magically work again when cool.
A little more troubleshooting can really narrow the field of possibilities on the gremlin.
Stuart | | |
