5 members (Gdads51, 55shaker, mick53, moparguy, 1 invisible), 140 guests, and 0 robots.
Topics128,086
Posts1,056,097
Members48,434
#460873 10/13/2008 12:22 AM
just put door on after doing some major metal replacement, got door fitting as good as i can, but have pretty good gap between front of door and fender, is there any way to adjust fender any to close gap a little
1955 CHEVY 3600 TF
might be, if there's some room at the cowl [dogleg] and it won't throw the hood joint off grin just gotta play with the whole front clip
Depending on how big the gap is, you might consider building up the edge of the door. This is a very commonplace trick among custom car builders trying to get a perfectly even gap.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I agree, you can either weld a piece of wire coat hanger or a small welding rod to the edge to help build it up
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
