| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 33 New Guy | | New Guy Joined: Jan 2008 Posts: 33 | just put door on after doing some major metal replacement, got door fitting as good as i can, but have pretty good gap between front of door and fender, is there any way to adjust fender any to close gap a little
1955 CHEVY 3600 TF
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be, if there's some room at the cowl [dogleg] and it won't throw the hood joint off  just gotta play with the whole front clip Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Depending on how big the gap is, you might consider building up the edge of the door. This is a very commonplace trick among custom car builders trying to get a perfectly even gap. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | Depending on how big the gap is, you might consider building up the edge of the door. This is a very commonplace trick among custom car builders trying to get a perfectly even gap. I agree, you can either weld a piece of wire coat hanger or a small welding rod to the edge to help build it up | | |
