7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46309 06/15/2005 12:17 AM | Joined: Aug 2003 Posts: 14 Junior Member | | Junior Member Joined: Aug 2003 Posts: 14 | I was wondering if a head off of a 235 out of a early 70s pickup will work on a 1961 block also if the intake man. and exaust man will fit on the 61 block thanks ahead of time | | |
#46310 06/15/2005 12:37 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The head out of a 70s pickup will only work if the original 70s engine had been swapped/replaced with a 235 from 1954-1962. | | |
#46311 06/15/2005 4:05 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Engines changed in 63 to the 230/250/292 series. Block is shorter and narrower. Nothing interchanges to the 235/261 series.
Fred 52 3600 69 C-10
#46312 08/16/2006 2:00 PM | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | When yall say shorter you mean block length for the 231/235 is shorter, right? How much so? With the increased block width you get increased bore, middle motor mounts and change in bell housing bolt pattern too, correct? | | |
#46313 08/16/2006 5:45 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | No, just the opposite. The 194,230 and 250 is both shorter lengthwise and heightwise while being about 24% less weight. The length is approx. 3" shorter. The 292 engine is approximately the same heigth as the old 235-261 family of engines due to it's longer stroke but the same length as the 194-250's. Hope that makes some semse to you. | | |
