0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#46309 06/15/2005 12:17 AM
Junior Member
Junior Member
I was wondering if a head off of a 235 out of a early 70s pickup will work on a 1961 block also if the intake man. and exaust man will fit on the 61 block thanks ahead of time
#46310 06/15/2005 12:37 AM
The head out of a 70s pickup will only work if the original 70s engine had been swapped/replaced with a 235 from 1954-1962.
#46311 06/15/2005 4:05 AM
Engines changed in 63 to the 230/250/292 series. Block is shorter and narrower. Nothing interchanges to the 235/261 series.
Fred
52 3600
69 C-10
#46312 08/16/2006 2:00 PM
When yall say shorter you mean block length for the 231/235 is shorter, right?
How much so?
With the increased block width you get increased bore, middle motor mounts and change in bell housing bolt pattern too, correct?
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
#46313 08/16/2006 5:45 PM
No, just the opposite. The 194,230 and 250 is both shorter lengthwise and heightwise while being about 24% less weight. The length is approx. 3" shorter. The 292 engine is approximately the same heigth as the old 235-261 family of engines due to it's longer stroke but the same length as the 194-250's.
Hope that makes some semse to you.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
