0 members (), 66 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
I'm getting ready to add a brake booster to the front disc brake conversion on my '66 C10. I've got a 350 with an Edelbrock performer manifold and it has a large, maybe 5/8" vacuum fitting hole behind the carb. Currently there is a fitting in the hole with a small (maybe 3/16") nipple for an vacuum hose that runs into the cab. I need to replace this fitting with one that has both the small nipple and a larger, maybe 3/8" nipple for the brake booster. So far I've looked at several of the disc brake conversion web sites, NAPA and Auto Zone web sites but have been unable to find one. Anybody know where I can find the double ended, 3/16" and 3/8" fitting I need. Is there another option? From what I've read its best to use vacuum off the manifold, not the carb.
Appreaciate any advice.
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
Riding in the Passing Lane
You should be able to make up something using hardware store pipe fittings or auto parts store. The small hose running to inside the cab must be for a vacuum gauge as I believe that model has electric wipers. It should be connected at the carb. smile
1972 Chevy c10 Cheyenne Super
Yeah your brakes will work a lot better hooked up directly to the manifold.As far as getting the fitting,most auto parts store usually have a pretty good selection.
Try looking at www.mcmaster.com. They have a lot of fittings but it'll take ya a while to look through them all.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
I don't have a vacuum gauge, but my truck has a Vintage Air A/C system in it. I'm thinking that small line goes to the A/C unit somewhere. I didn't see anything on NAPA's web site, but I'll stop there tomorrow and see what they have.
McMaster-Carr is a good alternative I hadn't thought about, I'll check there also.
Steve
