Brrrr
place holder
0 members (), 75 guests, and 1 robot.
Topics128,274
Posts1,058,431
Members48,489
Is there any difference between a 1947-54 3/4 ton flywheel on a GMC compared to Chevy? I know the motors are different but did they use the same flywheel? (SM 420 Transmission)
Thanks for the info...
Yup! Different flywheel. GMC flywheels won't bolt up to chevy... at least that runs true for the later 6 bolt flywheels that would have been on the 248, 270 and 302s. I am not sure about the earlier 4 bolt 228 flywheel, and if it will interchange with a 216 chevy flywheel.
The 1938 & 1939 Chevrolet 216 4-bolt flywheel is the same part as the 4-bolt flywheel used on the GMC 228 from 1939-52
