2 members (Otto Skorzeny, Nick in Manitou), 113 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#462832 10/18/2008 11:58 PM
just finished rebuilding the carb on my 36 207 and it fire up great then i turned it off so i could put my toe board and floor board back in so i could test drive it and make some adjustments but when i press down on the footstarter there is nothing. no turning over no noise at all. this truck has turned over everytime since ive had it until now. all baterry connections are fine even if they werent it would atleast crank over. anyone know what it is , what finally gave out after all these years?
The starter drive might be stuck in the flywheel. Put the transmission in gear and rock the truck forward and back.
Hope this helps. thumbs_up
If not, I would use a pair of jumper cables between the battery + to starter and battery - to engine(ground).
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #462844 10/19/2008 12:21 AM
christian s,
This might seem to obvious, but could the floor board or toe board be holding the linkage from mashing all the way down and allowing the thing to operate.
Stuart
atomarc #462859 10/19/2008 1:02 AM
That is possible, Open the hood and reach down to the starter and try pressing the starter button by hand, & see if the starter cranks over.
JeffL #462874 10/19/2008 1:45 AM
jdl Offline
I wouldn't put it past the battery cables. My truck started fine all the time until one day it just turned over once and then quit. The battery cable had lost connection at one end.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #462880 10/19/2008 1:59 AM
i tried pressing stater button manually and checking connections, rocking it back and forth but it still wouldnt start. then i went back later and it started, i drove it around the block, parked it and it wont turn over again.HMMMMMMMMMMMMMMMMMMMMMM?
Sounds like you have an open circuit in the cables/terminals. Did you try the jumper cable trick?
David Colter
54TOW #462885 10/19/2008 2:11 AM
no, but i took off the starter button cleaned the copper contacts and the baterry cable terminal at starter button and now it starts. So i probably did underestimate the cable.That would suit me just fine too. thanks guys
